Continued fitting the forward baffle floors. Each floor is unique and attaches differently to the engine. Connection brackets are made, fitted and drilled to the baffle floor, side baffle and the engine. The floors are also bent so that the forward edge of each baffle meets the lower lip of the cowl inlet. The bending is a result of a lot of trial and error and fittings to the engine.
