I completed the vacuum line connections from the regulator and filter to the attitude gyro and HSI. The extra hose length sits nicely without contacting any surface that may cause abrasion, and will allow easy access when the instrument panel section is removed. I also ran the hose from the vacuum pump to the regulator fitting on the firewall then secured this hose with cushioned clamps.
