I installed various cooling tubes in the baffels. In the left rear baffle a cooling tube runs down to the magneto. In the right front baffel inlet floor a cooling tube runs down to the alternator. In the right rear baffel a cooling tube runs to a cooling shroud that surrounds the vacuum pump. All tubes were secured in place with plastic ties or cushioned clamps and RTV was used to seal the baffel holes.
