I installed and safety wired the oil dipstick tube. With the baffles in place, I could reinstall the prop governor oil line through the forward baffle to the engine. I installed a rubber grommet at the hole and will later further secure this with RTV. I then reinstalled the heater hose that connects to a flange on the underside of the right inlet baffle ramp and runs to the heat muff.
