Brief Description: Various cooling holes in baffleing
I drilled holes in the baffleing for cooling conduit to the alternator, mag and vacuum pump. The alternator cooling comes from the right cowl inlet baffle floor. The magneto cooling comes from a hole in the left rear baffle. The vacuum pump cooling comes off of the right aft baffle. I'll clean up the holes when the baffles are off the engine prior to the final mounting.
