After installing the fuel line from the fuel injection to the fuel metering unit, I wasn't happy with the position of the hole in the rear baffle. While it probably wouldn't be a problem, the fuel line seemed to be stretched a little tight making the run through the baffle hole. By moving the hole down about 1 inch, the fuel line passes through with much more ease. I opened up the previous hole in the baffle and made a doubler plate and drilled a hole for the fuel line, then drilled to the baffle.
