Brief Description: Fuel lines and baffel pass throughs
There are two fuel lines that must pass through the rear baffels. One is the fuel return line from the purge valve to the firewall fitting, then onto the fuel line from the right fuel tank. The other fuel line runs from the front of the engine into the fuel metering unit on top of the engine. I drilled the baffels and enlarged the holes to accomodate the lines and rubber grommets. The lines are shown temporarily installed, as I will soon remove the baffels and prepare them for the final installation. After this, I will finish securing these fuel lines and torque the fittings.
