I adjusted the mounting of the electronic ignition modules that are mounted on top of the engine. I manufactured another bracket which moved the modules forward, which allows more room to attach the cable from the ignition control box. I then ran RG cable from the ignition control (which is mounted behind the firewall) and through the firewall. This cable will be routed to the ignition modules.
