I manufactured four rings out of .032" aluminum to be used for booties. These booties will be used where the aileron control rods enter the fuselage to prevent cold air from entering the cockpit. Each side will have two rings which will hold fabric, and the assembly will be screwed into the fuselage and the fabric will enclose the control rod. To be finished later.
