Brief Description: Secured Wiring under the Cockpit Floor
I took some time to clean up and secure the wiring run from the wing that enters the cockpit. I left plenty of extra wire in these areas for a service loop and now that the wing connections have been made it was time to clean this up and secure everything. I used plastic tie wraps on most areas to secure the wiring away from any control movements and points of possible abbrasion. The wiring that ran in from the left wing came close to the pitot tube connection bracket so I took the extra precaution of enclosing this bundle inside of plastic tubing.
