Bobs RV7 Site
Date:  1-31-2009
Number of Hours:  1.60
Brief Description:  Vacuum system
I began to plan the installation of the vacuum system. I started with the gyro instruments and determined that more room willl be needed behind the instruments for the vacuum line attachments. I cut an access hole in the sub panel which will allow these connections. I will also have to find locations for the vacuum regulator and intake filter before running the lines.
