Finished up installing rudder controls and rigging them. Still a few outstanding issues that have me scratching my head, but I will consult VAF and see if I can find answers.
+ Installed Right Idler (Rudder travel limited significantly due to insufficient cable length) + Moved Rudder Pedals to second forward most location (travel OK now, but not sure what the problem is?)
With the rudder peddals in the forward most position, there is not enough rudder cable (even with cable links attached on end holes). When I moved them aft one spot, everthing worked fine with the Cable Links still in the same position. This does not seem right to me, but I'll do some research to confirm.
Both Idlers installed and hooked up.
Had to move pedals aft one spot to get full rudder travel.
