Brief Description: Fabricated and Installed Access Panel
I framed in an area on the top of the right side behind the rear seat to use as access to the fuel tank area, wiring, etc. I didn’t like the idea of covering this area with no easy access. I formed the sides and bottom of the frame using 1” angle formed on a bending brake using 2023T3-.025. Next I cut and fitted a cover also of 2024T3. This is mounted to the frame using 8-32 X ½ machine screws and floating clipnut anchors.
