Chad's Challenger II Site
Date:  10-20-2006
Number of Hours:  4.00
Brief Description:  Gap Cover continued
I drilled the 1/2" hole in the front of the front cover for the pitot. A rubber grommet will be installed here to seal and cushion the pitot. I enlarged the center section mounting holes to allow for some adjustment. I added a floating anchor nut to the front of the center section so I can attach the front to the center section. I took measurements and started planning the rear section installation.
Rear view
Rear view
Rear side view
Rear side view
Rear view entire cover
