Brief Description: Installation of Gap Cover Center Section
I fitted the center section of the gap cover. I installed it using six 1.5" pieces of 12" AL angle riveted to the inside of the inboard wing ribs, 3 per side. I installed mini floating anchor nuts (8-32) in the horizontal surface. Later I will slightly enlarge the screw holes in the cover to allow a little alignment latitude. I don't like the fit where center meets front cover.
