Brief Description: Left Rear Fabric Attaching and Shrinking
I cemented down the fabric fore and aft of the gear leg using Poly-tak to keep this area stationary and keep the fabric from puckering in this area. I now cemented down the fabric covering the left rear side panel only as far down as the main longeron. I will finish the bottom portion with the fuselage turned upside-down. I shrunk this portion of the fabric at 250 degrees. The area behind the engine area was tricky and time consuming but turned out OK.
