Brief Description: Started covering the fuselage Sides
I re-prepped the rear fabric attach plates using two layers of surgical tape instead of Velcro to reduce bulk. I installed four vertical ribs between the top and bottom formers below the engine. This was in order to eliminate any distortion of the 1/2" tubes when tightening the fabric. I fabricated these ribs using flashing aluminum and forming into a 1/2" "U" shape for strength. These were very light but structurally quite rigid. I positioned the left rear fabric and cut the elongated hole for the main gear legs and hung the fabric in position using many clamps.
