Installed the Dynon heated pitot tube with AOA. The mounting bracket was attached with countersunk screws at the front and 2 #6 screws on the side of the bracket to the rib just inside of the bellcrank. The heater controller was mounted to the access hatch just over the bellcrank. The plumbing was routed through the ribs. The bracket and tube were removed until after paint.
