Finally got around to dimpling the skin. Ellen helped and we used the "C Frame" for all the interior hole and the hand squeezer for the edge ones. I also repaired two of the worst countersink scew-ups on the forward spar. I will post photos tomorrow after the JB Weld cures. I will also explain how I did it. For the countersinks that were goofed, but not as severe, I am just going to put in an "oops" rivet in there. An oops rivet is a 1/8'" rivet with a 3/32" head so it fills the countersink just like the 3/32" would, but has a larger diameter shank to fill in and be able to grab more material.
