I finally got back to work on the plane. First though, I had to buy a Dremel rotory tool in order to make the oval cut-out seen in the picture. That is where the trim cable will go through eventually. Ellen and I also deburred all the inboard and nose ribs. I am still waiting on some pre-fabricated parts so that I can rivet the foward spar together so I have had to skip ahead a little.
