Step 49: Reinstalled the two most outboard cushion clamps on Center Section Assy. per Construction Manual Page 31-03.
Step 50: Reconnected the Caliper Brake Lines to their fittings on the Inboard Main Gear Attach Brackets.
Step 51: N/A. No brake fluid yet.
Step 52: Reinstall Fuel Tank connected fuel lines to the tank. Bolted tank to the Baggage Bulkhead and using new frangible bolts to the Center Section.
Step 53: N/A. No ELT installed yet.
Step 54: N/A. No battery installed yet.
Step 55: N/A. Not adding fuel yet.
Step 56: Installed five inspection covers on the belly.
