Brief Description: Fine tunning the canopy tube frames
I spent about 2 hours fine tunning the front and rear tube frames. The process consisted of slowly trimming the tubes and placing the canopy on top until the point where everything fit just right. I temporarily installed the rubber trim around the canopy so that I can ensure a good seal. It took about 3 cycles of trimming tubes and placing the canopy and feeling my way around. After a while I decided to stop and continue tomorrow. Even though the fit had improved a lot ... I was not quite satisfied. Like I said this will be a long process.
