Brief Description: Hydraulic fluid in brake lines and other
This morning we pumped hydraulic fluid into the brake lines. This time around I tried using a small hand pump connected to the drain valve on the lowest point of the brakes pads. At the same time I had my son watch the top of the cylinders inside the cabin. It was so much easier than the method used on my first XL (which was basically the opposite - vacuum pump connected to the brake cylinders inside the cabin).
