Brief Description: 2.- Drilled the Rear Bottom Skin (Right Wiing)
First I leved off the rear channel with the Spar, then marked the ribs position and laid out the rivet lines. I then proceeded to pre drill the holes for the rear ribs. Once finished, deburred and set the skin once more in place so as to drill the rear ribs. Lots of drilling !
