Well... since I still have easy access to the rear fuselage, I decided to run the control cables for the elevator. Since the kids were playing in the backyard... I had to do this operation by myself. I came up with a nice trick that consisted of using a 10' 1/4" PVC pipe to help me run the control cables through the middle fuselage. Just run the pipe from the rear fuselage and set it right next to the corresponding routing holes of the rear channel... then just run the cable inside the pipe and push it all the way. Then just pull the pvc pipe and the cable will be waiting for you at the right place.
