Brief Description: Preparing for Stabilizer Install
This took quite a bit of time. Lots of fine tuning. Cutting the rear top skin for the elevator leading edge was certainly painful. I must have removed and installed the rear top skin about 15 times before I was happy with the results. One thing my EAA technical counselor said on my previous project is that you do not want to see the edge of the rear top skin rubbing against the elevator's skin, so I made sure I had a 2 -3 mm clearance.
