Once Installed I connected a small 12V battery and tested the new motor. I noticed that it delivers a deflection of about 20 degrees. This is more than enough for this aircraft ! Zenith is suppoed to come out with new drawings (revision) and I expect the new defletion to be noted since the current drawings call for 30 degrees.
