After measuring and laying out the rivet pattern I drilled the pilot holes for both spars by laying the webs next to each other (per the drawings). Then I proceeded to back drill the spar caps on each web. I also drilled out the 1/4" holes for the AN4 bolts. I used a piece of the wing templates from my first XL to test the fit between the center spar caps. Looks great !
