Worked on installing landing gear mounts. First made sure landing gear legs fit into landing gear mounts and drilled out attachment bolt area. Then cut holes in fuselage for landing gear and adjusted hole size until mounts fit into place. Then bolted landing gear mounts to fuselage to allow for cutting additional bolt/screw holes needed in side of fuselage. Also reamed out brake line hole and provided clearance in F-982B for landing gear mounts.
