Fabricated alternator starter link. Mounted alternator, then starter. Rough routed starter and alternator wiring, then attached to engine crankcase as diagrammed. Marked, drilled and inserted EGT probes into exhaust stacks. Inserted CHT probes into all cylinders. Routed and secured EGT/CHT wiring lines - still need to connect all engine compartment wiring (but it's routed to proper place). Master mechanic Daryl Sahnow shown at work! Yet to install alternator belt.
