N905AD Web site
Date:  12-8-2006
Number of Hours:  10.00
Manual Reference:  NA
Brief Description:  Engine Sensors
Mounted OAT sensor inside pilots air intake. Ready for wiring. Fabircated a mount for the fuel flow sensor above the gascolator. Fabricated inside backing plate and stiffener for mount. Mounted fuel flow sensor. Fabricated connecting tubing between gascolator and fuel flow sensor. Ready for wiring. Fabricated a magnetometer mount and drilled in place. Checked alignment with a digital protractor. Worked on flap indicator sensor setup. Fabricated connector for an adel clamp to be connected to the flap mechanism. Cut a threaded rod to desired length to connect the adel clamp to the flap indicator sensor. Need to measure sensor travel before final mounting of flap indicator sensor.
Fuel Flow Meter
Fuel Flow Meter
