Added brake lines to calipers on both sides. Also safety wired brake calipers. Now ready for brake fluid!Cut EFIS/EMS wiring harness holes in sub panel and installed wiring harnesses with grommets thru subpanels. Riveted in modified rib support and screwed in panel to make sure fit OK. Completed cutting remaining holes in panel.
