Safety wired gascolator muts. RPV'd and attached gascolator. Attached insigt angle fitting to gascolator. Ready for line to aux. fuel pump.RPV'd and attached cabin heat muff. Checked for free play. Ready for control cable.Removed engine mount to allow fixing interference with aux fuel pump platenut. Trimmed platenut, remounted engine mount and drilled out mounting holes. Removed engine mount for fitting of engine covers.Adjusted mounting bracket for see thru brake reservoir to provide adequate clearance from engine mount. Purchased a baffle mount for penetration thru firewall. Enlarged fireall access for this mount. Installed all fittings and mounted reservoir to firewall. Ready for brake lines to rudder pedals.Installed fittings into firewall sender unit manifold. Ready to install.Completed both hose mounts from air inlets to air control valves under panel.
