Completed reassembly of rudder pedals (had removed the rudder pedals buildups for powder coating); now ready to install rudder pedal assembly.Completed all riveting of forward deck; now ready for installation of this assembly when needed.Began construction of the cabin frame. Cut the access ports in the rear channels. Made the two connector plates and drilled required hole pattern. Fit the two aft channels together and clamped them to our drilling table. Measured for proper height and width. Installed the rear connector plate and drilled and clecoed this to the two channels. Fitted the lower inner strap to the channels. Ready for drilling.
