Fitted Forward Deck components for correct fit and clecoed together. Drilled holes in components after proper alignment. Cut, fit, and drilled seal supports to center and outboard panels. Marked the instrument panel for the toggle switches, breakers, and start switch. Fit both engine control brackets to the panels and marked control locations. Taped on mock-ups of panel components for review.
