Made a mount for the Whelan Strobe Power Supply (goes in airplane on side wall just behind baggage compartment). Mounted Strobe Power Supply and a terminal strip for connections. Attached input power connection to the terminal strip. Then attached the assembly to the side wall stiffeners with pop rivets. Then proceeded to determine how to route the wires back to the tail light. Cut grommet holes through rear bulkheads to allow feeding wires through a soft plastic hose line for protection. No electrical connections made yet.
