Brief Description: Seal Left Tank (Continued - just the baffle to go)
Photo #1 shows the 2d bay in from the inboard rib and the fuel level sender plate with both wires attached and covered in sealer (yep it looks like a mess and it is). Photo #2 shows the outboard bay with the fuel vent line pointing up near the fuel cap. Photo#3 shows the exterior of the outboard rib. Again I used quite a bit of sealer near the leading edge to prevent fuel leaks (I hope I got it right.) Tomorrow I should be able to seal the baffle in place and the inboard rib cover plate and seal the tank up tight. I will then let it cure over the next week and check for leaks when I get back from work.
