Brief Description: Seal Left Fuel Tank (Continued)
The fuel tank drain flange fits on the bottom exterior of the skin. Photo #1 shows the riveted in place drain flange and photo #2 shows the interior where I spread a good amount of sealer over the shop heads. You can see in photo #1 the sealer that oozed out inside when I riveted as you cannot see thru the flange. Yes, I did clean it out before it dried.
