Brief Description: Seal Left Fuel Tank (Continued)
Photo #1 shows the results after backriveting and then using a popsicle stick to spread the sealer around the edges and over the shop heads. Photo #2 shows what the skin looks like after the riveting process and before cleaning. Photo #3 shows the finished exterior result. Had a little sealer left over so went ahead and sealed the drain flange to the tank as well - see next entry.
Riveted in place and sealing spread over the shop heads
