Started the morning by constructing the wing jig since Anton was still home and he could help. First we erected the 4X4 Posts and secured them to the garage rafters and the floor using bolts and a bit of "Gorilla Glue." Then we built the cross beams and support beams for the main spars and attached them to the posts. My plan is to try to build both wings simultaneously so I constructed the jig to hold one wing on each side. Once I get the first wing mounted on the stand then I will built the bottom support beams and attach them.
