Brief Description: bottom L / Z gussets,longerons, lower rudder hinge
My son Brennan helped me put completed update right wing on wing rack.Decided to wait on right wing updates, need something different to keep incentive. Decided to start on fuselage. Drilled and clecoed rear bottom fuselage L and Z gussets on access opening. Drilled and clecoed longerons. Drilled and cleoced rear fuselage members. Drilled and clecoed rudder hinge assembly. Drilled #40 pilot holes for all assemblies will up drill holes next building time.
