Alans Web Site
Date: 11-5-2008
Number of Hours: 1.50
Brief Description: cut mock panel out of cardboard
Traced instrument panel on to carboard sheet. Located instruments and icom, transponder and avmap on carboard mock up. Used new tool from aircraft spruce to trace instrument hole patterns worked very well. Hard to see in picture not dark enough put instruments in groups. Avaionics on left side, tach, air fuel ratio gauge, ignition switch fuel pump selector switch, a and b configeration. Altimeter, air speed, AsI, turn coordinator. vent. On right side engine gauges, volt, amp, oil pressure, oil temp, outside air temp, carb temp, cht/egt gauge, hour meter. bus panel.vent. The icom 200 radio, transponder and avmap in centre of panel. Fuel management located in centre counsel, left and right fuel gauges. fuel pressure gauge, fuel gardian lights and test button. Room on left side of panel at bottom for future switches. Trim tab adjustment switches will be located on flight stick control, position indicators located left side below vsi. Located in centre below transponder he carb heat control, fresh air cab control, and cab heat control cable. I think I will trace over the mock up panel with a black pen, to get a better picture of gauge arrangement on camara. The compass will be mounted in centre top of panel.
