I decide I would up date the panel with toggle switches verses the rocker switches the power panel came with. I colour coded each toggle switch as per red for power and green and yellow for lights, landing lights or wing lights. I moved the ignition A/B switch from the left side of the instrument panel to the power panel and built a safe gaurd bracket around the switch. Installed a flap switch beside it with a cessna type gray cover with a marking (flap). On the left side of instrument panel were the A/B switch was located I installed a ignition switch with a push to choke feature, this ignition switch energize only the choke circuit and starter circuit. The Master switch on power panel will energize the power panel. Below were the ignition switch was I will be installing the throttle cable assembly and next to it were the push button for the electric choke was I am installing the fuel air mixture cable assembly.Just below the cht temp selector I will be installing the carb heat control, The carb temp gauge is to the left of this location, makes sense to install it there? there is room for flap lights neutrul 1/2 and full flap indication on right side of instrument panel I may put the flap lights there. The installation is a work progress, holes have to be cut for panel update.
