filed tank with 42 litres of methanol and a 250 ml of transmission oil to test for leaks on fuel sender and fittings. Pump the methanol mix with and extra fuel pump I had on hand. I made a quick test board to set up pump and 12 volt battery with switch and quick none sparking connections. No Leaks Drain and recovered methanol in original pails.
