Alans Web Site
Date:  6-25-2020
Brief Description:  lock tight screws on distributor
Locktie all screws on ignition distributor. Run wires through bottom of distributor housing. Install gear and washers. Install distributor on engine for custom installation of plug wires. Purchased 12 denso spark plugstwo different heat ranges and will replace gaskets with copper gaskets heat range 16 and 20. 20 is the colder plug.
installed on engine
installed on engine
WW Distributor
WW Distributor
denso spark plug gaskets
