I decide to put the ignition coils on the firewall engine side. Just about impossable to service and check ignition setup if under and behind dash without making an access panel. I will blast cool both the ignition and fuel systems. I order some lighter compact coil mounts from Jegs, I will install the coils just above the gascolator and coil isolator just below the Ellison fuel filter. I am going to cover the whole side with a panel that has a 2 inch male vent on top and exhaust out across the bottom where the gascolator is located. Pictures to follow
