Today I got the oil cooler installed along with the adapter and hoses that go between the oil filter and the engine. While I had the filter off I got the oil temperature sensor from Dynon installed as well. Started to get the baffles fitted as well, they sat okay, but will need some trimming on the bottom to fit around the cylinders as well as the cuts on top to fit the cowling.
