Brief Description: Riveting gusset plates and installing trim servo
Riveted on the second horizontal stabilizer gusset plate which went about the same as the first side - a little bit of drilling, but overall went on fine. Dan worked on installing the trim tab servo, and I did the wiring connections. The 5 wires were all connected with heat shrink crimp connectors. I was careful to take a photo of the connections because the wires coming off the servo (and what is described in the Ray Allen instructions) are not the same colors as the wire bundle running out of the elevator. Once that was in, the access plate over the servo was riveted shut.
