I put on the side panels for the center console today and the slid the fuel selector in place to see if it would fit and it was too wide with the 90 degree fittings on each side. I attamped to bend the sides out a little bit but it wasn't enough so I bent them back. I plan to order the 90 degree elbows right from Andair so that the fuel selector will fit in the center console. I also placed the top pieces of the control channel on to see the fit.
