Brief Description: Installing gascolators under seat pans
Installed the gascolators today, one for each side. I cut out a hole in the bottom skin below the seats using a fly cutter and then filed out a notch for the cage that holds the housing on the gascolator. Once in place I checked that the housing could still be removed from the underside of the airplane and then drilled out the three mounting brackets on each and clecoed in place.
